Hi all, I'm using REVITLT2018 and want to model by component. Is it available in this version or is there some other way I can model?
Cheers, Kurt
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
That's the one! I've noticed the limited modelling capability. I have solved my problem by creating my louvers using roof extrusion, it's a bit clunky but does the job. Are there any other solutions besides digging deeper into my pocket?
Cheers
Hi @Anonymous
I see that you are visiting for the first time. Welcome to the Autodesk community!
While Loadable family components (Doors, windows, etc.) can be used , In-place modeling (Walls only) can be done in Revit LT, you cannot shape edit roofs or floors) and you cannot model parts/ assemblies
Learn about the differences between Revit LT and Revit software.
Let em know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@Anonymous
How about trying curtain walls to design louvers?
You can try creating Profiles for the frame head, sill, and jambs, and one for the louver blade.
Set the Horizontal Grid Pattern layout to fixed distance
See HERE for more information and check out the video below:
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Viveka CD
Take a Curtain wall, edit the properties..
Remove Vertical Mullions.
Keep Horizontal and give fixed distance ( ex: 300 shown )
Keep Curtain panel empty..
thats it..
I have attached Revit file to understand more.
( am not sure whether you will be able to open the file considering Revit LT )
Cheers!
