Model brick return with different wall types
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
DanielKP2Z9V
382 Aufrufe, 6 Antworten
Is it possible to model this corner detail? I'm trying to make the external finish of one wall to continue on the other side.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: DanielKP2Z9V
They are literally two walls: one L and one straight. Disallow join between them.
Nachricht 3 von 7
DanielKP2Z9V
als Antwort auf: ToanDN
@ToanDN sorry, I should have clarified - this brick return is too short to create two separate walls (only 215mm shown in the brown line on the image below)
Nachricht 4 von 7
Create Parts from Walls, select individual Wall Layer(s), activate Shape Handles (under Properties) and drag ends of Wall Layers as required.  Use Merge Parts and/or Exclude Parts if necessary.
Help | About Parts | Autodesk
Nachricht 5 von 7
You can make a wall return of any length as long as it is greater than the wall thickness.  Is your wall thicker than 215 mm?
Nachricht 6 von 7
DanielKP2Z9V
@ToanDN yes, it's over 400mm
@barthbradley thanks, I'll try that
Nachricht 7 von 7
DanielKP2Z9V
I've ended up creating a generic model hosted on a well with a brick material and a void, as well as creating new wall types for these corners (splitting the wall at the ends). If anyone could come up with any other solution though please let me know.
