Model A Bridge Deck
Model A Bridge Deck
Gerald.Lockard
Message 1 of 21
Model A Bridge Deck
Gerald.Lockard
Is it possible to sweep in revit based on an imported 3d design string from autocad?
Replies (20)
Message 21 of 21
hanslammerts
 "Inventor is required to author new parametric bridge content.  The key is to be able to model complex geometry that is driven by parameters and thus, completely reusable.  This is the strength of Inventor.  We are starting to post a number of tutorial videos in the rolling sandbox bridge forum to provide guidance."
https://forums.autodesk.com/t5/infraworks-forum/june-7th-webcast-realistic-bridge-workflows/m-p/7112...
The way to make it work would be
Infraworks (with Inventor paramatric parts) -> AutoCAD Civil3D -> (? do we need Dynamo to get in between ?  ) -> Revit detailling
I would think it would be more logic to start as much as can form the beginning to get as little as possible parameters conversion in a one way situation
So the bridge Design should starts as much as possible here:
http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-C6F55B13-191F-49B0-ABFC-B7C696C78D72
