Hi all,
I'm a little stuck. Is it possible to have Casework/Furniture/Plumbing fixtures in a single schedule? It seems an obvious one but I can't seem to get my head around it.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von yurikim. Gehe zur Lösung
Then from there you can put some filters and delete what you don't want in the schedule
Hi @Anonymous
I helped you to press Accept as solution on your question.
In addition to @Anonymous's solution, once Multi-Category Schedule has been created, and if you see any Category that you don't want in the schedule, you can filter them out.
I have tried to create a simple example. Here we want to remove the "Site" category in this schedule. Set the filter as the screenshot below. You can add more conditions in the same manner for the categories that you don't want.
Hi, All working great thanks for the help. The only issue I now have is that the filters aren't working. Any idea? I did change the name from "Multi Category Schedule" but I doubt that is the issue.
The problem seems to be you can't filter by family & type or category.
I'm sure it's right under my nose.
