Hi Everyone,
I am struggling with a problem for 2 days. I really need to find an exact solution to that. As you see from the attached file, my curtain wall's border mullion cannot do mitre joint. Please show me or suggest to me any method or plugin for solving (I know this is a very chronic problem for Autodesk Revit comes from 2019 as I understood on web pages)
Horizontal and vertical mullions do not miter so I would use simple rectangle mullion with a detail component nested in the mullion profile family. If you want true 3D profiled mullions with miter joints then you would need to model them in custom panel families.
As for the recess / caulk joint around the curtain wall, see attached file for an approach.
