When using the pull down for the Wall types in Revit 2016, I am missing a significant amount of walls needed to finish a project. There is only a few different types of walls. Any suggestions?
Try this: In project browser, right click on families and use the "search" to lookup your type.
It seems as if the whole file for the type I am looking for has been deleted. It wasn't loaded in project browser and I also tried to copy the wall type from another project but it is completely dissipated from the computer I am running on.
Wall is a system family thus can't be loaded. You can only duplicate and create types. You can use transfer project standards to have wall types from another project.
Copy to clipboard then pasting in the new project will work also, only if both projects are opened in same instance of Revit.
Hello, did you open the right template like architectural template.thsnks
