Missing too many element error in Revit 2019.0.1
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1055 Aufrufe, 8 Antworten
I get "missing too many elements" error when trying to open 2018 revit projects and their backup files in Revit 2019.
- Tried to audit the model in Revit 2018, didn't work (same error)
- Removed corrupted families, didn't work
- Changed user profile, didn't work
- Installed Revit 2019.0.1, didn't work either
- Tried tons of solutions from the web, didn't work
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: Anonymous
Maybe try to check below and see if helos. thanks
https://forums.autodesk.com/t5/revit-architecture-forum/revit-error-too-many-missing-elements/td-p/7...
Nachricht 3 von 9
als Antwort auf: ennujozlagam
Thanks, already have tried these solutions, didn't help. Installed all of the updates, found some corrupt families and removed them, same error.
Nachricht 4 von 9
Viveka_CD
Hi @Anonymous
I'm sorry to hear that.
Have you updated Revit 2018 to the latest version?
Nachricht 5 von 9
als Antwort auf: Viveka_CD
Yes, I've installed 2018.3 update. The corrupt family solution worked for other similar models, but didn't for this one
Nachricht 6 von 9
Viveka_CD
Hi @Anonymous
Can you share the file and your journal with us to investigate further?
I can send you a private folder if you'd prefer.
Let me know.
Nachricht 7 von 9
aRcHiTeCt.JM
... that happened to me as well...
... unfortunatelly the only way to recover all was creating a new project ... copy- paste entire project  and later some adjustments for levels and others..
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2019-cannot-open-modeling/m-p/7933704#...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 8 von 9
Sorry, but unfortunately I cannot share a model.
I finally succeeded to recover a model out of one of the older backups.
Nachricht 9 von 9
Viveka_CD
Hi @Anonymous
No worries!
Glad to hear that you've got it resolved from your backups.
