I have noticed that I am missing 'Tab views' under View/Windows. This way I cannot use tabbed views at all. The only way to see titles of the tabs is 'cascade view'.
Is there any way to have 'Tab views'? I have already tried repairing Revit via uninstaller. Any changes.
I attach screenshot of 'Windows' panel.
Gelöst! Gehe zur Lösung
Gelöst von Alan.johnson1970. Gehe zur Lösung
Good point. Now i see that use Revit 2018
That is what happens then a man needs to use different pc. Simple things matters.
Thank you.
And how did you show the view tabs in 2018? I don't see view tabs here...
You can use ready-made Add-ons, for example, to COLOR YOUR TABS or change the POSITION OF WINDOWS (cascading / mosaic).
I attach to the video the coloring of the tabs by belonging to the open projects of Autodesk Revit.
Video on YouTube: https://youtu.be/b0PXfTu7xyw
Cascade/Mosaic
Colorizing Tabs In Autodesk Revit
Theme In Autodesk Revit
