Missing survey point and project base point (only occurs in elevation levels)
6 ANTWORTEN 6
Nachricht 1 von 7
eliz0305
3695 Aufrufe, 6 Antworten
I'm currently trying to edit a site plan view. The thing is:
- There is no survey point nor project base point to be seen in my site plan what so ever.
- In visibility/graphics menu all the boxes under Site is checked of. Meaning that the survey and project base point is visible in this site plan view
- I've tried to zoom out as much as possible but I can't seem to find any survey point or project base point in the whole project
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: eliz0305
If the SP and PBP Subcategories (under Site Category) are turned on in the View, then The Survey Point and Project Base Point are not within the View Range . Go to Plan View and move the Elevation Marker's Cut Plane so that the SP and PBP  are in front of it.
..."only occurs in elevation levels"?  Do you mean Elevation Views or Plan Views of Levels. Regardless, it's  all about View Range.  If the SP and PBP Categories turn on in the View, and  you are sure the SP and PBP are within the View Range, then maybe you hid them in the View.  Press "Reveal Hidden Elements".
Nachricht 3 von 7
Create a 3d view, no cropping, no section box, turn on Survey Point and Project base Point under VG, zoom extent (ZE).
Nachricht 4 von 7
eliz0305
als Antwort auf: ToanDN
It did make it appear in the 3D view but still not in the site plan
Nachricht 5 von 7
Did you set your View Range's Top, Bottom and Depth to "Unlimited", un-crop the View and Zoom All?
...and, of course, make sure the SP and PBP are not hidden in the View by Category, Element or Filter.
Nachricht 6 von 7
Set the Site Plan view range cut plane to 1000', top, bottom and depth to Unlimited.
Nachricht 7 von 7
lwebster
I am having the same issue. I have tried all these suggestions but it still does not appear in the site plan view. Has anyone figured out what is causing it to hide the survey point>? I can see the project base point.
