I am using Revit 2020 Student Version and I have a floor plans that have all of my gridlines, however in one of my section views only one grid line will not show up. All others are visible, and I checked and the grid line that is missing is not hidden. What can I do to solve this?
if the grid line is not included in your section box it will not display they are being cropped out
select your section tag and confirm the section box is positioned where you want it
Could be a grid line that isn't perfectly perpendicular (not at a 90 deg angle) to the section plane. If that's the problem, just fix the angle. Or, if you need to keep the angle of the grid line, you can cut the building perpendicularly to that grid line.
Any photos to add context to your problem?
MC
