Missing some floor plans
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1618 Aufrufe, 7 Antworten
Hi, I am experiencing some difficulty in viewing some of my floor plans. I checked under show hidden elements but it is not appearing, but once I recreate, it says `overlapping floor`. I tried to open them in the local file under a previous time append and it appeared. However opening under the main model, ticked under local file, the floor plans disappeared. Checked under visibility graphics and it is all ticked. Can anyone help?
7 ANTWORTEN 7
Nachricht 2 von 8
Kimtaurus
als Antwort auf: Anonymous
Based on your explanation I'm guessing your missing floors and not floor plans.
  • Is the category hidden in the floor plan where you can't see the floor?
  • Is there a filter to hide the floor?
  • Are there worksets? In which workset is this floor and is the workset visible?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 8
als Antwort auf: Kimtaurus
Sorry and thank you for helping. To be exact, the floor slabs for a few floors are is missing. The filter is registering 0. There are worksets and the worksets is set as visible.
Nachricht 4 von 8
Kimtaurus
Are the floors visible in sections?
What is the view range of the floor plan? Maybe it stops above the floor's level.
Set a surface pattern for the floor's finish layer, it's easier to see it in floor plan. Use the Reveal Hidden Elements tool to unhide hidden elements.
Nachricht 5 von 8
The floor slab is missing in the section. It is not visible under the reveal hidden elements. The view range is 2300mm and the cut plane is 1200mm. I am able to see them in the time append local file that I have saved, but unable to see them if i open from the main model somehow. Appreciate all your help.
Nachricht 6 von 8
Kimtaurus
In which Workset is the floor located? Is this workset visible in the view AND open?
Nachricht 7 von 8
The missing floor slabs are in the office workset that I am working on. In fact, some of the floor slabs in other stories are in the same workset and open.
Nachricht 8 von 8
You are totally right. Thank you very much. The few floor slabs was modeled under a different workset that was off. Thank you once again.
