Missing section line
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
495 Aufrufe, 2 Antworten
Hii
I cant see the sectionn line on one of the floorplans now. its still shows on the roof plan, though they are at the same scale.
 I looked at hidden element as well still not there.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Anonymous
@Anonymous
It could be that the vertical extents of the section do not cross with the lower floor(s) therefore you can't see it on the plan view of those levels.
To check and rectify that, place a perpendicular section to the one not showing or go to a leteral elevation view  >>> select the section >>> and drag its limits to cross with all floors you want to see it in
Ps: make sure in visibility graphics under annotations categories tab >>> sections are checked visible
Nachricht 3 von 3
Hey Thanks for the reply again !
I drew out a new section instead.
