Quick Question, about REVIT 2022, When opening a project, I no longer have a scroll bar on the initial project browser (autodesk docs, projects) When opening a project I have listed 9 total projects and only show 8 projects listed in my list. I can search and find the missing project but I am wondering where the scroll bar went and how to get it back. I looked to see if there were any updates or hotfixes to RVT2022 but there are no new updates. Just wondering if someone else is running into this issue?
This one? If so, change Windows Display Scaling to 100% see if it is coming back.
I am experiencing the same issue. Previously never had more than 8 projects in one Version of Revit and I just added a 9th to Revit 2022. Because of this I cannot see the project name at the Revit Level. Has there been a fix or work around for this?
We had the same issue. I did find the article below. It doesn't have a solution, basically just says it was fixed in 2023. You are still able to get to the project by searching for it. If I remember correctly, I believe it eventually fixed itself when we had this problem previously. It randomly pops up again here and there for different users.
