Hello everyone.
I can't find where to control the view range, in the view template in revit 20.
They have removed many options in the view template.
I hoped you can help
Regards Lasse
Nothing has been removed. Certain settings will not be available if they are not applicable to the view. Are you looking at a template for a 3D view?
Hello.
If you look in the properties (the image) you can see that you can change the view range. so it's it is relevant to the view template.
Did you see my first image ? there you can se the to diffrents for revit 19 and revit 20
I find out that I didnt had a template for floor plans. so I had to create a new one.
the problem is solved
@Anonymous wrote:there you can se the to diffrents for revit 19 and revit 20
Hello... That isn't the difference between versions. That is the difference between plan view and 3D view templates.
So, as I said, the view template that you were looking at was for 3D views.
