Missing Material from IFC Import
1 ANTWORT 1
Nachricht 1 von 2
laisM67YH
568 Aufrufe, 1 Antwort
I'm trying to open an IFC file in Revit, or import directly into a Revit project, but the model constantly loads without the materials. I have opened the IFC file on Autodesk Viewer and confirmed the materials are applied and exported correctly from Solidworks but when I import into Revit I get the attached errors. I've tried several IFC files and I get the same error. Does anyone know what may be causing this error and how to get the materials to import? I received the file from a client so I don't have access to the original Solidworks file.
If it's not possible, how can I apply materials in Revit to the IFC model?
Using Revit 2021.
Lais
Beschriftungen (5)
1 ANTWORT 1
Nachricht 2 von 2
Rafal.Gaweda
als Antwort auf: laisM67YH
Hi @laisM67YH
Can You  post example IFC file to check?
Rafal Gaweda
