Hi, I didn't find maps for materials. Seems like they haven't been installed on my computer. This problem exists even though I tried to uninstall and then reinstall Revit several times. Revit 2022 doesn't face this issue (v2023 I don't know).
Attached is the screenshot. Not only Asphalt Pavement but also many other materials. Where can I find the missing maps?
C:\Program Files\Common Files\Autodesk Shared\Materials\Textures\1\Mats
Or, install Everything from Voidtools and search for it.
Thanks. I navigate to that folder, but there are not enough images for materials. Is there any way to copy somewhere and past to it?
I don't understand how 2022 could be any different. All versions of Revit are using the same Material path. C:\Program Files\Common Files\Autodesk Shared\Materials\Textures\[1, 2 or 3]\Mats
As for the ones you are missing, see attachments.
As I said, I don't know why Revit 2024 doesn't have enough maps even though I reinstalled it. Here are screenshots, you guys can see the lack of asphalt maps you sent, and of course some other maps. I might copy/paste maps from 2022.
Still confused as to why one version behaves differently than another. All Autodesk products reference the exact same folders under C:\Program Files\Common Files\Autodesk Shared\Materials\Textures
This is how the folder structure should look:
..and under 1, 2 and 3, like this:
