Missing Level 1 - Unable to Create Floor Plan View
a00812364
a00812364
Hello!
Here's a strange one, any help would be appreciated!
I have a 'Level 1' missing in Views, and going to Views > Plan Views > Floor Plans doesn't give me an option to create a floor plan for this level.
I have elements drawn on Level 1, so I'd prefer not to delete this level and have it delete all the elements on Level 1.
Capture attached shows scenario.
Untick that box in your screenshot.
You sure it isn't one of the other ones there. Maybe you renamed it and not the corresponding level.
Just right click on it (the Level itself)  and pick Go to Floor Plan.
Corsten.Au
If you have any other floor plan / ceiling / structural etc created already, then it wont give option to recreate the view..
just check in your views...
you can even SCHEDULE Views, and select associated levels, and sort using levels...
you can pinpoint the view created for levels..
easy checking..
best luck
Corsten
Building Designer
RobDraw
Of course it will. You can have as many views based on any level as you want. If not, Revit would be pretty much useless. You just need to uncheck the box in the create views dialog box as already pointed out.
Rob
a00812364
Looks like this was it!
Thanks!
I was sure I checked all the levels for their corresponding names (but must had skipped the 'Site' level)
I could have created another floor plan by unchecking the 'do not create duplicates' box, but this is a much cleaner way of doing things.
Right-clicking the level marker in Elevation View, then clicking 'Go To View' is a really good way for checking this!
Thanks for the help everyone.
