Missing Keynotes TXT file
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
mhaeri
13110 Aufrufe, 21 Antworten
i inherited a revit 2018 model from another architect, they have used Keynotes in the drawings but did not include the appropriate text file. is there anyway I can clean the keynotes and start new? without the original txt files I can't edit the notes.
21 ANTWORTEN 21
Nachricht 2 von 22
als Antwort auf: mhaeri
No. But, you won't lose any that are placed either. You just can't pull new ones from the same file.
...just to be clear, you can edit the existing tags to pull data from a different file, if that is what you meant.  Just don't smoke while doing so.
Nachricht 3 von 22
mhaeri
als Antwort auf: barthbradley
That is not what I was hoping :leicht_lächelndes_Gesicht:
We need to be able to modify notes, spelling, directions, ETC. In my opinion this needs to improve
Nachricht 4 von 22
You cannot modify what you don't have. Ask them for the keynote file.
Nachricht 5 von 22
What would be improved?  were you provided the text file with the rvt?  if so, load it. If not, there's not much in the way of programming that can mitigate that.
Nachricht 6 von 22
mhaeri
No the txt file was not provided. The title of my question is “missing txt file” otherwise there would be no issue
Nachricht 7 von 22
mhaeri
als Antwort auf: ToanDN
The other Architect is not responding.
Nachricht 8 von 22
Then you need to export a full keynote legend to excel and re-format it to create a keynote txt file.
Nachricht 9 von 22
mhaeri
Thanks, I will try that next
Nachricht 10 von 22
Yes, I understand the issue. You don't have the source file from which the current keynotes were derived. So, you have several choices.
1. Leave the current keynotes as-is.
2. Replace the current keynotes with keynote from your own file.
3. Get the original keynote file that the current keynotes were pulled from.
That's about the size of it.
FWIW: Keynote Manager is the simple, efficient way to edit Revit's keynote files.  I highly recommended it.
https://apps.autodesk.com/RVT/en/Detail/Index?id=604656466920293522
Nachricht 11 von 22
mhaeri
Thank you. I am in the process of retyping the notes and replacing the txt file.
Thanks for your response.
Nachricht 12 von 22
You're welcome.
Nachricht 13 von 22
jimbell153
Open the list in Legends, and open Keynote Legend.
With it open, Go to File>Export>Reports>Keynote Legend.txt
The you can edit the text file, save it in the project Revit Folder and navigate to it
in the Annotate tab>Keynotes>Keynote Settings.
And Bob's your uncle.
Nachricht 14 von 22
jimbell153
Nachricht 15 von 22
MichaelWolff
als Antwort auf: jimbell153
Am I right in thinking this only works for keynotes that are already tagged somewhere?
Nachricht 16 von 22
MichaelWolff
For now, the add-in stiKeynotes.com does the trick and allows to export all keynotes (whether annotated somewhere or not) into a text file. If the text file is not there (and it is not judging from your description), there is a fallback folder.
Nachricht 17 von 22
jimbell153
als Antwort auf: MichaelWolff
When I downloaded and started to install https://stikeynotes.com/ I got the message:
Microsoft Defender SmartScreen prevented an unrecognized app from starting. Running this app might put your PC at risk.
Have you experienced this?
Nachricht 18 von 22
MichaelWolff
I routinely check everything I download from the web with the anti virus app (mcaffee) installed on my machine. If that gives me a thumbs up, I use the piece. I think in this case, Windows considers an msi-file to be fishy. Best luck!
Nachricht 19 von 22
jimbell153
Nachricht 20 von 22
MichaelWolff
Yes, I got the same message when I tried installing the add-in with Revit running in the bg. When I restarted Revit everything worked out.
