Missing grid in elevation
I'm having trouble with the grid lines in my elevation view. I cannot find them. I checked the visibility and still can't seem to find a way.
Please help.
Thanks.
cbcarch
check here:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
There are two possibilities:
- its 3d extent is not within the elevation view range: select the grid on any view, right click and maximize 3d extent.  Alternatively, create an overall scopebox and assign it to all your levels and grids
- it is not perpendicular to the elevation view direction: no cure except faking it
