Missing Geometry (family) in Revit Model
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
joyUQQ7M
288 Aufrufe, 4 Antworten
Hello my revit model shows certain windows cutting through the walls in elevation but not in section, is there a way to fix this?
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: joyUQQ7M
try to activate your icon BULB it could be hidden in the view and see if helps.
Nachricht 3 von 5
ennujozlagam
check this
https://forums.autodesk.com/t5/revit-architecture-forum/windows-shown-in-elevation-amp-3d-wont-appea...
Nachricht 4 von 5
syman2000
Check and see if the window and the 3d is at the same phase. Right now I see it as 02_New Construction. If that isn't the issue, check design option and see if the window is in the wrong design option.
Nachricht 5 von 5
Check phasing of the 3d view (phase and phase filter).
