Hi @Anonymous
Right click and delete the view from your browser. Then select View -> Plan Views -> Floor Plan. Level 2 should show up in the dialog box. Hopefully creating a new view should give you what you need.
If this doesn't work, per RDAOU's suggestion, check the View Range.
