All of a sudden my English-Imperial Templates do not appear when I go to create a new family. I only see 'English', and only Metric templates appear. Any ideas why this is occurring and how to correct it? Thank you.
Gelöst! Gehe zur Lösung
Gelöst von PhilvK. Gehe zur Lösung
If you go one step up where does it take you
Under Options >> File Location, I use the path to the parent directory/folder then from there pick which Library to pick. I need several but you could reset it to a specific one.
Found it. I have no idea how, but the entire directory got moved into the French sub-directory. I moved it back. It seems to be fine.
cool
mark your reply as solution to close the post
