Missing Elevator Family
Message 1 of 15
Greetings All,
I downloaded and installed the trial version of Revit 2021.  After using a tutorial to play with it I found many of the families had not been installed.  I downloaded and installed the set from the Revit download page, but it's missing elevators.  My understanding was it used to be there, now it doesn't seem to be.  I don't want to be going to a third party to install their product when an Autodesk Revit model exists.  Or used to exist.
Did I miss something or is there a separate area on Autodesk to download the elevators?
Replies (14)
Message 2 of 15
There's no "Elevator" Families OOTB. I'm not even sure what an "Elevator" Family is.  Is it a Family that moves up and down?
Message 3 of 15
Perhaps I'm using the wrong term.  There's a group for doors, a group for stairs, railings, floors, ducts, pipes, etc.  I thought these were called families. To insert a door or stair into a model you had to load the group into the model and select the style of door, stair, or whatever.  I want to insert an elevator and there's no group for it, nor can I find a download for it here.
Message 4 of 15
yah, I'm not following you too well.
What's an elevator? A platform or compartment housed in a shaft for raising and lowering people or things to different floors or levels.  Right?
Try this...
Message 5 of 15
Looks like you're following me just fine.  Thank you.
Message 6 of 15
I wouldn't be bashful about downloading content from on-line. Thank your lucky stars that you found it on-line.  That means you can cut out early and go have a beer with the gang.
Here's another...
Message 7 of 15
syman2000
I assume you are referring to Specialty Equipment>Elevators and Lifts.
Message 8 of 15
Interesting. I found 'em under "Venus, Mars, Saturn and Jupiter".  😉
Message 9 of 15
thanks, was looking for English Imperial but those will work.
Message 10 of 15
Thanks for posting this question--I couldn't find it either. It's missing from 'English-Imperial'>Specialty Equipment, but can be found under the more generic 'English'>Specialty Equipment category.
Message 11 of 15
The only thing I have under English is Structural Precast.  Certainly not in there.😁
Message 12 of 15
Do you have an "English" and "English-Imperial" folder under C:\ProgramData\Autodesk\RVT 2021\Templates?
Maybe you didn't download it.
Autodesk Revit 2021 Content | Revit Products 2021 | Autodesk Knowledge Network
Message 13 of 15
Did you notice that @syman2000  posted the content for you in a ZIP file? Nice of him to do so. Don't you agree?
Message 14 of 15
fle
there are just some basic elevator families in Revit. Btw, there is a very powerful and the free #elevator #plugin for Revit "DigiPara Elevatorarchitect" available at:
https://www.digipara.com/products/elevatorarchitect/
Hope that helps,
Andreas
Message 15 of 15
billatarcat9MS5L
We also have some elevator options for you as well: free elevator revit families .
I hope one will help you out. 🙂
