Missing Elevation Tag
1 ANTWORT 1
Nachricht 1 von 2
robinG3P9Q
165 Aufrufe, 1 Antwort
I know a lot of people have had a similar issue, but I've tried all the suggestions, and I can't find the elevation tags for 3 elevations that are on a sheet.
I tested, and it's not possible to delete the elevation tag without deleting the corresponding elevation, so since the elevation clearly still exists (it's on a sheet), the elevation tag must exist somewhere, mustn't it? But it's nowhere to be found. I checked if it was hidden, I checked the phasing, I checked that the drawing scale wasn't the issue, still can't find it.
Then I learned about right clicking on the elevation and selecting "find referring views", so I've done that, and I get a dialog box saying "Could not find referring object."...
What do I do now? I wanted to change the exact positioning of the elevation view, but I don't know how to do that without having access to the elevation tag, and I don't want to have to redo all of the work already done to the existing section. Help me? Thank you very much.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: robinG3P9Q
Exterior elevation tags could be outside of the plan's view crop. Check view's filters. Check discipline....
