hello! floor and doors do not appear on my level 2 plan view, you can see it appear in 3D view though. Elements/categories are not hidden whatsoever, thank you!
Gelöst! Gehe zur Lösung
Gelöst von LanggamanXavierMassed. Gehe zur Lösung
check your view range, phasing, check if there is assigned view template set none and activate your bulb icon if there are hidden objects. thanks
or check your Discipline, try to change to Architectural and see if helps. thanks
nice...![]()
