I am using revit 2019. When I open the Revit model from central file, error comes out and don’t let open the model
Here is the erro:“ The file <filename>.rvt cannot be opened. There are too many elements missing in it. Please contact Autodesk Support.“
I am only one can’t open the model as my colleagues working on same model can open the model form central file.
Strange. Exact same file is being accessed and opened by multiple others, but you can't? Have you tried opening the file with Audit checked yet?
Open the Journal file then try to find this missed elements and open your file by Detach one and Audit it then when it open purge unused elements then save with another name and reopen it again
