I added some wall elements to an option set and then in that option, created parts.
Now the wall doesn't appear in my main model.
I tried adding the wall from the option set back to the model but it didn't let me.
Gelöst! Gehe zur Lösung
Gelöst von cbt990. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You need to manually cut paste aligned in place elements in a Design Option back to Main Model.
So the expanded warning says exactly what the errors are and how to overcome them. Is there anything not clear?
I was able to resolve this by changing visibility to "show original" and then copy/paste aligned.
