I AM HAVING ISSUES WITH CERTAIN ELEMENTS (WALLS, TOPOGRAPHY, PROPERTY LINE) NOT SHOWING WHEN I GO FROM ONE FLOOR PLAN TO THE NEXT. MY ELEVATION MARKERS ARE MISSING TOO. IT'S NOT HIDDEN IN VIEW, CHECKED VG, RH AND VR. OPENING AND CLOSING ELEMENTS SOMETIMES SHOWS UP.
Gelöst! Gehe zur Lösung
Check your View's Phase
Here's 32 other possibilities:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
you can try this go to the view you be able to see everything, create a view template and give name, apply this view template to views missing elements after you apply set to none again and see if helps. thanks
try to check your view range setting or your phasing. alternatively if you can share the file to troubleshoot. thanks
I have found out the problem. I used an older file to use as base for my new project. I ended had to delete all the floor plans and elevations to make it work
