missing dwg layout
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
282 Aufrufe, 1 Antwort
missing dwg layout
hi
i get dwg with two layouts which are created in  Autocad mobile. when i open it , i get just one layout, not both. how can i get both layouts in revit??
the dwg is in attachment
1 ANTWORT 1
Nachricht 2 von 2
constantin.stroescu
als Antwort auf: Anonymous
As I have seen you made your flowchart drawing direct into Layout 2.
In such a case I'll save the Layout as an independent .dwg file ant then insert into a Revit Drafting View.
  • in AutoCAD >  Layout 2 > Save As - do not click , just hoaver over the comand with the mouse> choose Save Layout as Drawing
  • Open the new  created .dwg file and scale it , because Revit does not accept too short segments - Save again
  • in Revit , into a Drafting View , insert the .dwg file.
Have a look at my screencast.
https://knowledge.autodesk.com/community/screencast/94dc604f-f621-4c08-9e1c-751c54b2aca4
Constantin Stroescu
