Have had this issue on a few projects and cannot find a fix or a reason that would causes this issue.
When I have a dimension string, Revit will delete one or multiple dimensions from the sting, but not remove the entire dimensions string. See the attached screen shot.
What causes this issue and is there a way to fix this without deleting and redoing he entire string?
Myles
Link copied
