I have multiple detail & model groups in my model that are visible in plan/section/3D views etc, but when I look under "Groups" in the project browser, there is nothing in the menu. If I try to search the name of the groups, it tells me "no matches found".
Why is this?
Hello @mlem7VFYU
Did you manually create those group or it becomes group coz' you are using Array command?
Well that strange, The only Group that didn't reflect on the project browser was the group created using Array even if the array are already exploded.
If you don't mind, can you share the file?
Hi @mlem7VFYU
Welcome to the Autodesk Community!
Thanks for posting on our forum.
I wanted to follow up on this issue - Can you send us a file to troubleshoot further? I can send you a provate folder if you want.
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Share the file. Let's take a look. Without it, we're just guessing.
I had the same issue - R2019.2. I closed and reopened the project browser and the groups repopulated.
