Missing Default Ribbon Panel – Unable to Restore After Reset/Reinstall
smlee0521
smlee0521
I am trying to recover some of the default Ribbon panels in Revit that have disappeared.
I already tried reinstalling Revit and resetting the UI, but the panel still does not appear.
I would like to know if there is any detailed information about controlling the size of a panel or turning a panel on/off through Regedit or %AppData% settings.
I also tried importing and using a UI file from another environment where the panel is visible, but it did not make the panel appear in my Revit.
Is there any other way to restore this missing panel?
smlee0521
I’m trying to use the Extrusion tool in the Family Editor, but the Forms panel doesn’t appear when I open most .rfa families. Interestingly, when I open a Mechanical Equipment family, the Forms panel is visible.
Is there a way to make the Forms panel always visible regardless of the family/template I open?
Thanks!
Pavankumar_H
Hello @smlee0521
Thanks for writing to us on forum.
In order to Reset the Revit UI, please use the following article which gives you clear step-by-step guidance.
How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings
Full Revit version: Regarding your Forms Panel query, please follow the steps as in image attached.
Please do share your observations.
Thank you!
mari.shimode
Hi @smlee0521, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
mari.shimode
Hi @smlee0521, since @KumarPavn's reply is useful to the community, I have marked it as an accepted solution so others who have the same question can refer to it.
Mari Shimode
