Missing Cut Pattern tab under Material Browser
8 ANTWORTEN 8
Nachricht 1 von 9
1671 Aufrufe, 8 Antworten
Hello everyone,
I am currently working on a phase of a project that does not require wall patterns/fills to be shown on the plan.
I am aware that I can turn off the visibility per view/sheet in the Visibility/Graphics Overrides; However, I would like to turn off the wall patterns globally.
Now, I am aware that I can turn off the patterns globally by editing the wall assembly and changing the pattern in the material browser to none but herein lies the problem. For some strange reason, the standard options " Shading, Surface Pattern, & Cut Pattern" are not shown under the Graphics tab.
Does anyone have an idea why this is happening? I have attached screenshots of the material browser on the project being worked on and one from the standard Revit architectural template.
Thank you.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Restart Revit.
By the way, you don't need to change the materials. Just open Object Styles > Walls and turn off Cut pattern. That will do globally for the project unless you VG a view and turn it on.
Nachricht 3 von 9
...or use Course Detail Level in Plan Views. That would do the trick. No?
Nachricht 4 von 9
als Antwort auf: barthbradley
@barthbradley
Thank you for your input but no, that doesn't work. What happens when I change the detail level to coarse is that it will now show my stud walls as 2 lines which creates another challenge for me as I need to show the studs on the plans.
Nachricht 5 von 9
als Antwort auf: ToanDN
@ToanDN
Thank you for your reply but I don't see any option to turn off the Cut Pattern from the Model Objects tab inside the Object Styles window. If I click on the Material column, that's where I get a cut pattern option inside the graphics tab of the material browser which is already set to none. am using Revit 2016.Capture.JPG
Nachricht 6 von 9
Sorry. That indeed does not exist. Pattern columns only show under VG so you need to turn it off for the views, or create a View Template and turn it off there.
Nachricht 7 von 9
@ToanDN
I guess for now the workaround would be to VG then turn off patterns on every view that does not require a wall pattern. Although this does not answer my original question, the solutions we've discussed so far will do for now.
Nachricht 8 von 9
@Anonymous wrote:
@barthbradley
Why not then just turn your wall into Parts and hide all but the Stud Core Layer in the View?
Nachricht 9 von 9
Corsten.Au
1. Fix the Material Browser
This might help\
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-no-material-browser/m-p/7579450#M...
2. If there are only few wall types which you are trying to fix, then Just Create " dedicated" wall types
for this phase ( Ex: Phase 1 - Wall A, Phase 1 - Wall B) without the pattern and in the next phase replace
all of them with new wall Types ( Ex: Phase 2 - Wall A, Phase 2 - Wall B)
make sure, the thickness of the walls remains same..
hope that helps
Cheers
Corsten
Building Designer
