As I was drawing out my project in Revit 2020, I noticed that the number of basic walls options have decreased to include only 4. As I recall, a brand new Revit 2020 project will have many basic wall options and I am wondering why are most of the basic wall options gone.
What template did you start with? Be sure you are using the Default or Architecture template to have more wall selections. Even better, create your own template with your wall types already defined.
@evydm5 wrote:
I started with a architecture template.
The 4 walls you show in your image are not even names of walls that are in the standard Revit default architecture template. You may have started with a template, but it is NOT the one that ships with Revit. I would suggest a reinstall of Revit to make sure you have all of the correct content installed.
