Mirroring the Text in Section Head
18 ANTWORTEN 18
GELÖST
Nachricht 1 von 19
suganesh_matrix_a540
873 Aufrufe, 18 Antworten
Hello everyone
I was wondering if there is any way to mirror the text inside the section head when i flip the direction?
As you can see in the below images the section head is flipped but the text remains oriented to one direction only.
Thank you
18 ANTWORTEN 18
Nachricht 2 von 19
Simon_Weel
als Antwort auf: suganesh_matrix_a540
Why would you need to have the text mirrored?
Nachricht 3 von 19
syman2000
I assume this is what you are looking for
The trick to copy the section head family and rotate the text as shown in the screenshot below
Set the new section type using the rotate text section head.
As a result you should be able to get the section rotate the way you wanted.
Nachricht 4 von 19
als Antwort auf: Simon_Weel
I meant mirroring it the following way:
The direction of the detail number shout be oriented towards the arrow
Nachricht 5 von 19
als Antwort auf: syman2000
ohh yea this is what i was looking for ! will try it out !
Nachricht 6 von 19
Thanks ! It worked. I was just wondering if there is any settings in revit to do that instead of rotating the text?
Nachricht 7 von 19
Do you also want the label to be up side down when the section is looking down the page?
Nachricht 8 von 19
als Antwort auf: ToanDN
What a timing :leicht_lächelndes_Gesicht: I was about to ask that !
Yes i want it to face upside down.
Nachricht 9 von 19
Do you like them that way or is there a convention that you need to follow?
Nachricht 10 von 19
It's a requirement of the office. Mostly they use AutoCAD so they end up rotating the text.
Nachricht 11 von 19
syman2000
Sadly Revit don't have much option.  Even if you check off keep readable, it won't do much. Even rotating the text will not show as rotated in the project.
So if you want the upside down text, the only option is to download upside text and replace the current text. You can download San Serif upside down text from the link below
https://www.fontspace.com/upside-down-sans-serif-narrow-font-f30963
Nachricht 12 von 19
Well then I have nothing to offer but I sincerely hope your office covers the employees' neck injury insurance.
giphy
Nachricht 13 von 19
blank...
That's a really weird one to cling to. Just tell them it can't be done.
Nachricht 14 von 19
I hope they do :Gesicht_mit_Freudentränen:. I know it's a weird requirement, anyways thanks, but there seems to be another issue. The method suggested by @syman2000 works, but depending on the direction the section line is drawn the text gets flipped. See the attached image. Dot indicates the start point and arrow is the direction the line was drawn. Any solutions?
Nachricht 15 von 19
syman2000
Depends on how you rotate the text.
Nachricht 16 von 19
Alright. So I need to maintain any one direction and use the flip arrow I guess, cos if I rotate the text the other way then the text is oriented correctly in the first section line but it affects the text in the second section line and vice versa.
Nachricht 17 von 19
Is it possible to mirror text to show correctly for basketball floor striping?
Nachricht 18 von 19
mhiserZFHXS
als Antwort auf: todd_freebairn
I'm guessing you want to rotate it, not mirror it. Select the text, and uncheck "Keep Readable" in the properties. Then you can rotate it however you like.
Nachricht 19 von 19
todd_freebairn
als Antwort auf: mhiserZFHXS
Yes.. rotate.  Thanks for this!
