Mirroring full model with annotations and section cuts 100%
JoshuamRivera
JoshuamRivera
If you had issues needing to mirror your structure on an existing project for an existing project or for a new project. Usually it would be a bust with annotations , and or other elements.
Solutions is, (example):
Open all your floor plan view levels, for better visibility activate them using your Tile Views. Do the following to each view one at a time, window select all elements , annotations etc, then go to the next view, keeping CTRL button pressed, go ahead and select all elements, annotations, etc of second view. Do the same for the rest of your plan views. Once you get to your last view , you can see you have everything selected on all your views. Final go click on Mirror command using pick axis or draw axis. And tada!
Keep in mind if you had any elements end points not locked to its adjacent element it may stay behind. Example , a steel beam not locked to the vertical steel column, it may not bring it along smoothly.
This also is used when needing to rotate your Structure.
Their may be some other more detail and additional steps to make this happen, but for the disciplines moving such a fast paced and extremely busy work environment and no time to BIM manage it or RD it , hope this solution works wonders for you.
Mirror Project?
...I would never, ever use the Mirror Command to mirror an entire Project.  Been there. Done that. Regretted it.
JoshuamRivera
Yes we all know mirror project.
My explanation is for example there are 5 buildings in the same model. bldg #1 is the same as bldg #3 but mirrored. That mirror project is not the way to go in that case.
What we do is fully design bldg 1, 2, 4, 5 once we get close enough to permit set then we go and mirror bldg #1 to Become also in the same model bldg #3. To keep in the same model, annotations, section cuts and all.
5 in 1? So you're creating 5 different submittals from one project? Wow! How the heck do you manage that?  With booze?  😉
JoshuamRivera
Lol, no booze, I just drink Tea   .....Teaquila
No, the submittal is the 5 building structures together. All design coordination occurs up to 90% DD/CD set. Once the deadline for AHJ permit submittal is down the barrel that is when we go ahead and do our Revit shenanigans and do our hole in the wall magic.
