Mirroring Framing Groups - Not Flipping Correctly
4 ANTWORTEN 4
Nachricht 1 von 5
BigPicture045
339 Aufrufe, 4 Antworten
I use model groups for my roofs if they are symmetric. This can drastically increase workflow and reduce errors. However, when modeling framing members, the model groups do not mirror correctly as you can see here:
Notice how the far side gable end framing member is rotated incorrectly. I have posted this in the sturctural forum, but unfortunately, we were not able to get a solution for using model groups in this manner.
Here is another example where the members are not mirrored correctly. You can see the C channels are facing the same way. However, they should both be facing towards the ridge:
And lastly, you can see on the roof plan, the members are not flipped symmetrically about the ridge:
Again, I've posted this in the structural forums without any luck and I am hoping to get some answers here.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: BigPicture045
Mirroring Groups? That violates a commandment, I think.
Okay, maybe not one of the Ten Commandments, but it does go against Best Practices.
Working with groups in Revit (autodesk.com)
Nachricht 3 von 5
BigPicture045
Well it's hard to go back once you start doing it for symmetrical buildings. Creating and updating groups goes soooo much faster. I've done entire apartment buildings this way and its a game changer. The modeling is reduced to 1/4 and when you make changes you only have to update 1 group. I've been able to solve every issue I've come across, except this one.
Nachricht 4 von 5
I don't know how to respond. Does "sorry" work?
As for grouping and mirroring structural framing, I can foresee problems.  Structural Framing Families are very intelligent in the Project. They can get fussy as is.
Nachricht 5 von 5
azad.Nanva
post your roof here if it is possible.
