I need a floor plan to be mirrored on a sheet with all annotations. Why is it that we are able to rotate views on sheets 90 degrees but not mirror them? Any solutions?
Tell me which one below you can read?
@rmartinezYHTMP wrote:I need a floor plan to be mirrored on a sheet with all annotations. Any solutions?
Nope.
Nope.
I need to do this in one project, I linked the main project to an empty new project, then I mirrored the link
you'll need to use "by linked view" from RVT Link display settings
*The vertical text and dimension will be mirrored
This is a temporary solution for you.
Why don't you Copy and Mirror the Project?
