- Mute
- Permalink
- Report
Hi all,
I would really like to be able to create mirrored, dependent views in Revit. Is this possible?
Ideally I need to have my regular project and associated sheets, alongside handed sheets with the dependent mirrored views on. My thinking is this would allow me to use the same legends/detail groups ect, keeping both drawings exactly the same (but mirrored obviously). I've used the rotate on the crop extents before, it's not obvious how you could mirror it though.
I understand you can save as, 'mirror project. This doesn't work too well for nested groups and also is not dependent on the original version.
Another option I'm aware of is linking the file and mirroring using the modify tab. This is better, but how are sheets ect. recreated in this project? Will it bring though detail lines ect? I suppose I can re-load any legends and re-use the same, but would still be easier if they were in the same project.
Can anyone shed some light or come up with another alternative?
Thanks in advance,
Jake
