Mirror material not showing in "realistic"mode
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
Pantaleon02
6560 Aufrufe, 9 Antworten
Is it normal that the mirror material looks black in the "Realistic mode" in Revit? I tried this in another computer with the same result.
How can I change This?
9 ANTWORTEN 9
Nachricht 2 von 10
Ilic.Andrej
als Antwort auf: Pantaleon02
Well, you could play with the Photographic Exposure but that will affect the whole model. Without it, the "realistic" mode is generally dark...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 10
Pantaleon02
als Antwort auf: Ilic.Andrej
@Ilic.Andrej  So... Is it normal that the "mirror" looks black? or is i just my pc?
Nachricht 4 von 10
Ilic.Andrej
It is not your computer, everything is fine. Without reflections, mirrors are black in every 3D program. To display mirrors accurately, you need Ray Tracing. Follow the link and read about it, its an interesting subject.
Andrej Ilić
MSc Arch
Nachricht 5 von 10
don't duplicate the material.......
create the new material and assign the colors to it...........
Nachricht 6 von 10
Viveka_CD
Hi @Pantaleon02
Can you check if you have Hardware acceleration enabled?
To enable Hardware Acceleration:
Options > Graphics > Graphics Mode > Use Hardware Acceleration (Direct3D®).
Let me know if this helps with your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Nachricht 7 von 10
Pantaleon02
@Ilic.Andrej Ok... Interesting.
Black color for a mirror is not very "realistic" at all. Haha.
I thought it was something with my pc...
Nachricht 8 von 10
Pantaleon02
als Antwort auf: Viveka_CD
Hello  @Viveka_CD
Yes, I have that option on :leicht_lächelndes_Gesicht: ... I also updated my drivers before posting this question here, thinking maybe it was a driver issue or something. But, same result.
Nachricht 9 von 10
Corsten.Au
You can change the colour of the mirror Glass.. but it will show up in consistent colour setting..
only ray-traced will give the reflection..
Cheers!
Corsten
Building Designer
Nachricht 10 von 10
Pantaleon02
als Antwort auf: Corsten.Au
@Corsten.Au Thanks :leicht_lächelndes_Gesicht:
