AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
MIRROR FLOOR FLIP SURFACE PATTERN
9 ANTWORTEN 9
Nachricht 1 von 10
2411 Aufrufe, 9 Antworten
Hello Community!!!
Has anyone realized that when you mirror a floor with a surface pattern the surface pattern of the new floor is flipped 90 degrees,
Is this a bug of the software?
Many thanks and Merry Christmas to all...
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Looks like a bug. You know how to re-align the surface pattern, right? Better yet, you could duplicate the original floor, edit the boundary and mirror it, instead of mirroring the floor itself.
Nachricht 3 von 10
Thanks ToanDN for the workaround but I would like to include the floor in a group and I need to mirror the group after. I hope autodesk fix that bug asap.
Nachricht 4 von 10
Kimtaurus
Actually I don't think it's a bug. You mirror the element, thus the pattern is mirrored as well.
It follows Revit's logic. If you mirror any another element everything is mirrored: patterns, shared elements, reference planes,...
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 5 von 10
als Antwort auf: Kimtaurus
Problem is that the pattern is not mirrored, but rotated 90 degrees.
Nachricht 6 von 10
I would like to hear what Autodesk have to say about this kind of bugs instead of thinking about making money.
Nachricht 7 von 10
myoudall
Has this been addressed?  Help!!
Nachricht 8 von 10
als Antwort auf: myoudall
- Constrain the surface pattern
- Make a Group
- Mirror the Group
(This is a workflow proposed by @BIM.Consultant but I cannot find his original post at the moment.)
Nachricht 9 von 10
BIM.Consultant
als Antwort auf: ToanDN
Thanks for the mention @ToanDN
The original post is located here: https://forums.autodesk.com/t5/revit-architecture-forum/help-mirrored-group-elements-do-not-retain-s...
As per your video, the alignment will not work (if mirroring with an angle) and instead you should place dimension and lock it to have the constrain.
Nachricht 10 von 10
AngusBS7AS
als Antwort auf: BIM.Consultant
I'm currently working in Revit 2020 and I am no longer able to replicate the solution above, when using an angled pattern. I've used this fix previously on an early project completed in Revit 2018, but when attempted in Revit 2020 I recieve the error message "The References of the highlighted Dimension are no longer parallel."
Have you been able to replicate this fix in 2020 or have you made note of a different solution?
Thanks!
In Foren verƶffentlichen
