alguém poderia me ajudar?
tenho o plano educacional, recebi a confirmação da autodesk. Baixei o Revit 2021 e ao logar com minha conta, ele não aparece minha licença, portanto estou usando a versão teste de 30 dias.
Como consigo mudar a licença ou onde acho o serial number para desbloquear?
try to contact autodesk technical support and see if helps. thanks
send PM to these autodesk personnel maybe they could help ypu.. thanks
Hi @Anonymous ,
Welcome to the Autodesk community. Thank you for reaching out. I have checked internally and found that a case has already been submitted to the support team on the 8th of Feb.
You should receive a notification in your inbox about the case.
Rest assured someone will be in touch with you. Let me know if you have questions.
