Min pc for revit work
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
599 Aufrufe, 4 Antworten
Hi Friends, could you please let me know what would be the minimum CPU, Graphic card and etc. for Revit work. I know Autodesk has a guidance in this regard, but it is confusing for me. Thanks
4 ANTWORTEN 4
Nachricht 2 von 5
Avaris.
als Antwort auf: Anonymous
What makes it confusing? What kind of information do you need? Are you refering to this guide?
Nachricht 3 von 5
als Antwort auf: Avaris.
yes, For example, it says "SSE2 " for CPU type, and I don't' know what it is. I found a dell one which has this specs:
DELL OPTIPLEX 790 SFF I7 2600 3.4 GHZ 16.0 GB 500GB DVD WIN 10 PRO 5YR WTY USB WIFI - Refurbished
Could you please let me know if it is good?
Nachricht 4 von 5
Avaris.
SSE2 is a kind of processor instruction, nearly every CPU since 2000 has this. I would say your option is a medium variant. It has probably an old processor like i7 2600, but if you are working on small/medium models it is sufficient.
Nachricht 5 von 5
eventura75
It will all depend on the complexity of your model.
Things that affect it are the amount of families loaded, size of work, views detail.
As for the CPU, I have been able to work on a 1.90GHz with 4GB RAM and no dedicated graphics card, again I kept Complexity to a minimum.
