Hi all,
I'm looking for courses, tutorials or books which are focused on preparing construction documents and transforming office CAD standards to Revit.
Advice and suggestions are welcomed.
Gelöst! Gehe zur Lösung
Gelöst von mpeperkamp. Gehe zur Lösung
Hi @yk,
Check this forum item:
Succes whit Revit.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
@yk hello, you can also check it HERE. thanks
Don't think you have to reinvent the wheel.....
In certain situations, it may be appropriate to just bring your standard ACAD details into a Revit Drafting View and use them as they are.
You can also import ACAD details into Revit and explode them- this will turn them into native Revit elements- so you can then amend, adapt as required.
Consider making a Revit "Library" project where you can store all you 2D Revit detail views and bring them into each project as appropriate.
