Middle Support in Landing
6 ANTWORTEN 6
Nachricht 1 von 7
alex60
8843 Aufrufe, 6 Antworten
Hi all, I need to make a stair like the one in the attached image, but the middle support  does not continue along the landing and don't find out the way to do it. Any help will be helpful.
thanks in advance, Alex
6 ANTWORTEN 6
Nachricht 2 von 7
chrisplyler
als Antwort auf: alex60
Instead of turning on center support and turning off the left/right supports, turn off only one of the side stringers and offset the other one an appropriate ammount to make it center.
I just made a default stair type, turned off the left stringer, changed the right stringer to open and gave it an offset that put it in the center, turned off the risers, and deleted the rails. But if all else fails, you could always model-in-place whatever you want.
Nachricht 3 von 7
alex60
Hi all, the problem is that my stair has both stringers and the middle support. See the attached image.
Thanks in advance, Alex
Nachricht 4 von 7
chrisplyler
Then use  a beam, or model-in-place a component, that will serve the purpose.
Nachricht 5 von 7
constantin.stroescu
In such a situation I 'll use a trick:
  1. first , I'll place a side open carriage , using offset into the middle of the scale - as Chris suggested in his previous post
  2. then I'll create a new Railing type with the first railing at 0,00 , based on a new created profile with the dimensions desired for the side closed carriages. The material of this first Rail-Carriage will be chosed as desired - could be different from the other rails and balusters....
Constantin Stroescu
Nachricht 6 von 7
thanks ad!
Nachricht 7 von 7
tuncaytBK48C
als Antwort auf: Anonymous
hey could you solve the problem ? I have the same issue.....
