Middle button configuration
Message 1 of 8
I'm actually having a configuration problem on my mouse by using Revit 2017 and Autocad 2017.
One week ago when I was clicking on the middle button the action on Revit was a "PAN ZOOM" (showing the entire view)
Now when I click on the middle button I always have this "PAN ZOOM" action, but when I click longer on the button I also have a "ZOOM +" action.
Does anybody have the same problem ?
Is it possible to delete this "ZOOM +" action and to keep the "PAN ZOOM" for the middle button ?
Because when I use this button I it often activate the 2 actions and I always have to Zoom - after that ...
Thanks in advance,
(Sorry for my French-glish)
Replies (7)
Message 2 of 8
patrick.emin
Hello, for your information, we have also a french Revit forum: http://forums.autodesk.com/t5/revit-et-bim-francais/bd-p/198
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 3 of 8
What is the brand/model of your mouse?
Message 4 of 8
Hi ToanDN,
My mouse is a Logitech M505,
And I'm actually working with Win 7.
Do you think that it can be a driver problem ?
(Thanks Patrick,
I will think at the French section for the next post)
Message 5 of 8
M505 mouse's wheel has several functions: scroll up/down (Zoom In/Out), tilt left/right, and click (middle button).  It is very easy for you to activate the scroll or tilt motions when you press the wheel down to PAN in Revit.  I have another Logitech model and I have to set another button to be the middle button.  Unfortunately, a M505 does not have the extra button that my mouse does, so you may want to open the Logitech mouse software and deactivate the Tilt functions.  You can change it either universally for the mouse, or add Revit.exe under Advanced settings and change it only for this program.
Message 6 of 8
Viveka_CD
Hi @Anonymous
The function of the middle mouse can vary by software application.
Click the Revit symbol in the top left corner. then go to steering wheel and uncheck zoom increment.
If you recently adjusted your dual monitor properties, there is a chance that the setting overrides mouse settings.
To Update your mouse drivers, click here
Message 7 of 8
Thanks for your answers !
The solution for my problem was to uninstall and reinstall the Logitech driver and software.
Message 8 of 8
Viveka_CD
Hi @Anonymous
Bonne journéeSmiley Happy
Glad you were able to get the mouse clicking!
Let us know if you have any additional questions. Happy to help!
As suggested by @patrick.emin you can post in the Revit French forum Revit Et BIM - Français
Thank you @patrick.emin for suggesting the french forum and @ToanDN for the illustration!
