Mid level doors not appearing
2 ANTWORTEN 2
Nachricht 1 von 3
344 Aufrufe, 2 Antworten
See attached screen shot of Level 1 doors that appear slightly below the level on "grade" do not appear to cut through the walls at level 1, which makes since and is accurate. However, is it possible to adjust this setting so that when viewing Level 1 is it clear the door cuts through the opening?
2 ANTWORTEN 2
Nachricht 2 von 3
loboarch
als Antwort auf: Anonymous
You can try using a Plan Region in those areas.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-594B7B97-0D59-4B03-9544-E403BD03BE48
It lets those specific areas have a different view range than the main floor plan.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 3
chrisplyler
How far are these doors offset below the level? Do they not still pass through the view's cut plane?
I give exterior doors a negative offset quite often, but it's usually in the neighborhood of -1.5" and so doesn't change the plan view at all. They are still cut by a 4'-6" cut plane just fine, and display no differently than other doors.
If your doors are too low to intercept the cut plane, then you might try just lowering that cut plane a bit. If they're so low that lowering the cut plane causes other problems, then use Plan Regions to lower the cut plane only in the specific areas of the doors as necessary.
