Microsoft Surface Studio issues with Revit 2017
4 ANTWORTEN 4
Nachricht 1 von 5
1701 Aufrufe, 4 Antworten
Hi all,
I recently purchased the Microsoft Surface Studio and cannot get Revit to work at all without instantly crashing the program. The display within the program window flickers a bit, then crashes. I've tried adjusting the dpi to 100% but that only made everything else on the computer far too small. Any thoughts on what could be the problem? Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
i am having same problem. I think it has to do with 4k high resolution support rather than graphics hardware acceleration. still tinkering.
Nachricht 3 von 5
erik
Autocad 2018 has support for 4k.
Nachricht 4 von 5
update2017-05-20:
Revit2015,2016,&2017 do not run on MS Surface Studio running Win10Pro.
However Revit2017.2 does indeed run AOK. Note that .2 release I am referring to here is not service pack2 which is different.
Nachricht 5 von 5
one more interesting clarification:
4K resolution refers to 3840horizontal pixels
however MS Surface Studio actually has even higher 4500horizontal pixels.
this is subtle but important difference.
FYI: so far Revit2017.2 is running fine at 4500.
