Microsoft Surface Studio 2 compatibility with Autocad & Revit
14 ANTWORTEN 14
Nachricht 1 von 15
a.alkadam
6270 Aufrufe, 14 Antworten
Hello
Any Idea about Microsoft Surface Studio 2 compatibility with Autocad & Revit? Surface Dial is not a big deal, I'm asking about graphic card issues and power of the gear itself? is't worth?
Thanks :leicht_lächelndes_Gesicht:
14 ANTWORTEN 14
Nachricht 2 von 15
ennujozlagam
als Antwort auf: a.alkadam
hello, you can refer to this LINK previous threads. thanks
Nachricht 3 von 15
I am hoping someone (from AutoCAD) will respond to a.alkadam's thread regarding whether Microsoft's Surface Studio-2 is compatible with AutoCAD and Revit?
@a.alkadam wrote:
Hello
Nachricht 4 von 15
als Antwort auf: Anonymous
why?
just look up the specs on the internet or read through the other threads that were given above
Nachricht 5 von 15
Big help (zero). There are no threads giving any information on this; also I am hoping AutoCAD would respond as the NVIDIA® GeForce® GTX 1070 8GB GDDR5 used in the Surface Studio 2 is 'not' on AutoCAD's recommended or certified graphics hardware list (only NVidia's Quadro Series is listed).
Nachricht 6 von 15
If you want someone that uses Autocad to respond then you need to post this on the Autocad forum....this is the Revit Forum.   Or did you mean Autodesk and not Autocad?
The GTX 1070 will run Revit and Autocad just fine.....but...while the Surface Studio 2 is an awesome setup, I question the cooling aspect when under load.  Very similar to a laptop without enough fans.
Nachricht 7 von 15
Actually I would be using it for both AutoCAD and Revit. Thanks for the reply...very helpful..!
Nachricht 8 von 15
I would also like to buy Surface Studio 2. and I also use Revit 2019 ...
did you buy it at the end?
Nachricht 9 von 15
a.alkadam
Yes I did. It is awesome. I so happy with it so far.
Nachricht 10 von 15
steve
Matteo - you have a surface studio and are using with Revit?   Your thoughts?
Nachricht 11 von 15
als Antwort auf: steve
Steve - let's say I use revit since they put it on the market... but in the same way I draw so much by hand (watercolour, sketches, paint, digital…). When I saw this product (Surface Studio 2) I thought I could only use one device to do the two things ... I'm trying to understand if is a good product for both ...
Nachricht 12 von 15
andreas_buender
Hi Matteo,
Do you know more about Surface Studio 2 and Revit 2019 or newer?
I use revit since more than 9 years and Onenote sind it was included in Office.
I read the sound of the ventilator can be a problem.
Did you bought one?
Greetings Andreas
Nachricht 13 von 15
steve
als Antwort auf: andreas_buender
I mostly like the monitor - the "all in one" form is not important to me.  In reading the very gear-headed reviews the picture painted by these wonks is alot of carping about the out of date processors yet amazing speed and beauty of the final product.  Bottom line is - why do power users like us need an all-in-one form factor?  give us a system with that phenomenal touch screen, "dial" and tools with a big-old box that sits on the floor - who cares.   In the middle of thinking all this and "woulding it be nice", the folks at Autodesk send me a promo showing smiling super-wonky insiders gathered around an "Autodesk" logo on a Microsoft Surface Studio 2.   Ha!
Nachricht 14 von 15
steve
2 years later, my update is:  surface studio display and pen based interface, fantastic, but underpowered for larger revit project.   Mine has been retired from my desk on to other duties.
Nachricht 15 von 15
f.annoscia1XRNMD
@steve, What do you think of the new surface studio laptop with intel core i7 for larger Revit project?
It is recommended for architects, designers and engineers on the Microsoft site and also for the use of Autocad, I do not read about Revit, however.
https://www.microsoft.com/EN-US/surface/business/surface-laptop-studio
