Hello all,
I installed for Revit 2018 the Metric US Libary in Englih from this link (https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...) ,
but it doesn't contain all the families (see image below).
I have the same problem with the others libraries. Only the French library is well-installed.
Do you know the reason?
Thank you in advance!
Not sure....but instead of downloading it that way, I would try updating the library via the Add or Remove Programs.
Select the library version that you want to update....click the Uninstall button. Yeah, I hate it that it won't select Modify. When the Revit splash screen pops up it will let you "Add or Remove Features". Scroll through and select US Metric. I usually add UK, Australia and Canada too, as there are some families available there that are not in the US folders. Let it download and install when you select Next. If Revit is open you will probably need to restart to see the families.
I have this video that show differents way to do that if you want to follow, the only problem is that i recorded in Spanish.
